I will soon have four Pirelli P6 185/65 R14 86H tyres for sale, unused still with labels attached.
They are too wide for my BX on 5.5J Speedlines so going for Michelin 165x70 R14 instead.
£220 ONO for all four plus delivery (or pickup at the CCC National next month)
4off Pirelli P6 185x65 R14 for sale, unused - £220
Neil
A476 RBX
Series 1 BX 16TRS
A476 RBX
Series 1 BX 16TRS
Re: 4off Pirelli P6 185x65 R14 for sale, unused - £220
185's should be fine on a 5.5" rim as they are 'ideal tyre' width for 5.5 and ok for 5" - 6.5" rims?
http://www.alloywheels.com/Tyre_Calculator" onclick="window.open(this.href);return false;
Equivalency table
Rim width, Minimum tyre width, Ideal tyre width, Maximum tyre width,
5,0 Inches, 155 mm , 165 or 175 mm, 185 mm
5,5 Inches, 165 mm, 175 or 185 mm, 195 mm
6,0 Inches, 175 mm, 185 or 195 mm, 205 mm
Equivalency table
The problem is rear wheel arch clearance on my BX (mk1).
On the low setting then are just touching the front of the nearside rear wheel arch. The rear wings were replaced with N/s sill 20years agoso must have had a slight his alignment
Neil
A476 RBX
Series 1 BX 16TRS
A476 RBX
Series 1 BX 16TRS
- MULLEY
Don't put it in low I think most people gently knock the rear wings out a bit to make the clearance so that they'll fit without rubbing.
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 82
I trimmed the lip a few mill to clear the 205/40 R17's, there is a good 8mm of lip to play with!
