o/s/r window channel needed bx hatch
as above the metal channel piece that the rear window sits into (rubber) as mine has completely rotted away one end hence the window opening at a jaunty angle, common problem.
Re: o/s/r window channel needed bx hatch
here is price and part No.'s of both the front and rear door window channel's,
95633347 SCHEIBENUNTERKANTE 14.72 GBP 17.66 GBP 17.66 GBP
95633346 BASE DE LUNA 12.81 GBP 15.37 GBP 15.37 GBP
the top one is for the rear door window but is NFP
were as the second one is for the front door window which is showing as still available,
i think you could buy front one and cut it down to fit the rear window
regards maklcolm
regards maklcolm
