To suit top mount inter cooler with the oil breather on the far n/s and associated breather hoses if possible.
A non egr one please.
I have installed the later type labrynth style fuel filter housing/heater which fouls the mounts for the oil breather regulator. Later types have the regulator mounted towards the n/s of the intercooler but the bolt holes for the later type intercooler and older inlet manifold are different.
Wanted: Late BX TD or 405 TD Inlet Manifold
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: Wanted: Late BX TD or 405 TD Inlet Manifold
I know this isn't what you are after, but I have one from a Xantia TD which would suit the fitment of a front mount intercooler...
pretty sure I have that shizzle mate. I'll have a looksy when able
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Thanks Matt, no it's not what I'm after thanks, although I have one of those too!
I could steal yours though, that's the one I'm after! The bolt hole on the end is moved by approx 10mm, presumably to prevent fitment of wrong manifold!
Thanks Doc you old Goat, queen portraits and beer at your disposal!
feck off man! You can have it!
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
You I want you, can I have you instead
ahh go on then! Surcharge on returns though
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Ooooo I hear you Docceroo, you always want a bit of slap'n'tickle you, ya cheeky bitch!
and cheap!
Dont forget I'm cheap!
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
How could I after last time? Brighton pier has never meant the same since. Still, the donkey went to a good home, I was glad about that.
