I have noticed my clutch pedal is VERY high, it is way above the brake pedal and nearly fowling the trim panel.
In use it works fine, with no slip, I'm used to it, but maybe it is a little harsh.
Could this just be tired clutch cable, or is it more likely the clutch itself is worn and needs changing
My car has the clutch cable/arm that does not have the push rod adjustment and the threaded section on the engine end of the cable looks to be done up a long way along it's thread...
Thanks, Simon.
