My BX GTI Auto is kicking out smoke when started from hot (no smoke at any other time) and with 175k on the clock I think the valve seals are shot. As I want to keep the car and as the rest of it is in good order and a rare spec (black wheels, aircon as well) I'd like to get it done. I'll then fix all the other bits that need doing - a sort of rolling restoration
Can anyone recommend a good local specialist?
Thanks
BX GTI Auto
2CV Special (restored in bleu celeste)
Saab 9000 Griffin 3.0V6 (for sale soon)
911 Carrera (993)
Daimler Super V8
Mini Cooper Sports pack
Mercedes SLK 230
Peugeot 205 GTI auto (coming soon)
I live in Cambridge and take my BX to Pleiades in Sawtry. I can highly recommend them. You can get the bus back to Huntingdon pretty easily (I get the guided bus back to Cambridge via Huntingdon).
Phone Martin on 01487 831239 an tell him James with the blue BX 14 sent you. I'm sure he'd be able to do the work you want and if not will happily give you the time I day and recommend someone local.
Good luck,
James
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Can't comment on Bourne for their work as they're a bit far from me to take the car to, but they certainly know their stuff, Barry is a BX fan and their parts prices are very good!
Just under 40 miles in t'other direction you have Chevronics in Hitchin. Rob Moss is also a BX fan who really knows his stuff, expensive owing to closer-to-London location. I've been pleased with both Barry and Rob's care of my P&J
if this is an 8v engine fairly easy to diy, at same time replace/lap the valves and re shim. i would imagine a fairly hefty bill from a garage to do the work.
Depends on costs, time available and inclination really - If you want to do it yourself, a top end gasket set, a head skim if required, and maybe some shims for resetting the clearances should come in for under £100. You may find that the valve stems and guides are worn - I'd get new guides fitted by a specialist as I've heard of people cracking heads removing the old ones, but the rest is just a matter of being patient and methodical.
or another option is to remove the head and send it off to a specialist or a local one may even collect, maybe worth a few enquiries first and get some quotes as i would expect a bill for £500 ish to rebuild a head. or even try a mobile mechanic as their hourly rates tend to be half that of a garage.
