I'm wondering in reality how much it's worth and whether it might be worth taking on and resurecting / get an idea of what to offer.
I like the model and spec so i'd be interested in restoring it.
Good points:
nice colour, although very faded on the wings and doors but the bonnet and roof + bumper were resprayed and so look good.
mk1 alloys - nice!
autobox was smooth, fluid a good colour
not much rust in usual places (no salt on the roads) but just beginning around 1 rear door shut / front wings okish, but alarmingly a 2mm gap above the driver's side door hinge where it has rusted through. Rear boot seam looked pretty good.
All electrics work, although sunroof could do with a lube.
Was owned by a Citroen dealer up to 2003 and 115000 miles who it sounds like looked after it. Current owner 10 years.
I asked if it used any oil - apparently not.
Rode well, no sign of rear arm bearing wear.
Glovebox not broken
Bad points:
It hasn't had an NCT (Irish MOT) for 2 or 3 years
Engine was very lumpy, still a bit so when warmed up. Plugs, points may sort this.
Needs new accumulator sphere, belt, possibly cambelt, All fluids changing although didn't look in too bad condition.
Very difficult to start - does alot of cranking cause excessive engine wear?
It's only done 20,000 miles in the last 10 years
Cracked windscreen
Rear spoiler very perished
Interior faded and seat covers frayed / torn in places. Rattly steering column shroud.
Tappety noise from engine, possible piston slap under load. Would need a good tune up.
So how much is it worth? Scrap? a bit more for rarity?
If i could get it running smoothly, get it welded, i could see myself running and enjoying it, as long as it doesn't start burning oil (valve stem seals may become an issue)
Any opinions much appreciated
