Has any one ever removed one of these intact ?
I am trying to remove two with the seal intact and am failing so far.
The BOL indicates to push it down and forwards then lever it out gently inwards, if only it were that easy.
Any tips anyone please ?
1/4 lights
- x 117
1/4 lights
- x 94
Re: 1/4 lights
Bloody nightmare they are. Lots of jimmying the seal against the door frame, swearing and wiggling saw mine out.
Re: 1/4 lights
Yes! They were a faff as kitch says, lots of WD40, remove the central plastic trim finisher and remove the door trim panel which will make things alot clearer!
- x 117
Re: 1/4 lights
Ah ! so it can be done. I will try some lubricant.
Re: 1/4 lights
Let us know how you get on - I have this job in my future too!
bx_pallas
Re: 1/4 lights
Remove verything around them and heat the seal with blow dryer. I got mine out without heating the seal, but afterwards I thought it might have been easier If I did so.
Re: 1/4 lights
I'm assuming from the descriptions above that everyone's talking about the small fixed windows in the back doors.
bx_pallas
Re: 1/4 lights
Yes it has come to my mind whats meant, thanks! I was thinking of lights (shining lights) and a little confused. Sorry, I'm no native speaker
Re: 1/4 lights
No worries - I have enough problems with English, let alone anyone elses language!
saintjamesy89
1990 Volvo 740 2.3 GLE Estate
Re: 1/4 lights
I used the screwdriver method (being very careful of the paintwork underneath). Most of the seal came away with mine, but I still had to get the white spirit out for the residue, also under mine I found a load of hard yellow stuff, almost like very dense expanding foam adhesive stuff that I had to chip off with a screwdriver.
2013 Nissan Leaf Acenta 24Kw
