I had an idea today to convert the GT's dis-functioning oil level gauge into a more useful temperature gauge...
Rationalle being that the oil level gauge, even if it was working, is rather redundant if your car doesn't use any oil...besides which if it did use oil I think I'd be checking the level manually...
So Why not convert this needle to indicate engine temp, and also the warning light behind the needle would be useful as its bright and cannot be ignored....It will be interesting to see if the resistance range for the oil level metre is similar to that of a temp gauge..failing that I'm sure that a temp gauge needle could be crafted into the same position..
Anyway...just a thought...
Cold as the moon here right now,, but on the home stretch to Spring
GT temp gauge in instruments
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX TRS mk1 auto... SOLD
90 BX TRi..parts....cubed
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
- mat_fenwick
- x 19
Re: GT temp gauge in instruments
If you find out what the respective resistance ranges are, you could add resistors in series and parallel to the sender to make it electrically match up. Gets more tricky if one is non-linear though...
I agree Mat, if it gets to that or needs LESS resistance then i'll experiment with a MK2 temp gauge headmat_fenwick wrote:If you find out what the respective resistance ranges are, you could add resistors in series and parallel to the sender to make it electrically match up. Gets more tricky if one is non-linear though...
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
- Tim Leech
- x 148
I have a spare set of BX GT clocks if that helps...
Thanks Tim .(think I got the right name this time), are the clocks all separated or still in the whole cluster??Tim Leech wrote:I have a spare set of BX GT clocks if that helps...
Why I ask is that I'm also needing a replacement speedo head, but thinking the shipping of the whole cluster might be exxy..not sure..
What Would you take for "the clocks"? to help me decide...
I really do need the speedo but as I have found MK2 heads are not the same..They fit but read very inaccurately after about 60kmh.. Besides which my odo went berserk and has stuck and clicks loudly which also causes the speedo needle to flick
Ash
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
- Tim Leech
- x 148
Hi Ash
Its a complete clock set in a grey surround I bought a few years ago for about £25? I think as a spare but have since bought a complete new speedo. It has MPH and k/mh on them.
Happy to post at cost. Would want to see the whole thing if at all.
