Fault
Modstox257
Fault
Post by Modstox257 »
Does any model of BX have an EOBD socket ?
Andy c:
1992 Citroen BX Hatchback 1.9D (Red) FOR SALE !
1993 Vauxhall Nova Van 1.5D (Blue)
1977 Mini Clubman 1275GT (Brown/Blue ''Restoration'')
1968 Ford Anglia Saloon Deluxe (Blue ''Restoration'')
1989 Volvo 240 GL Saloon 2.0L non turbo (Blue)
1989 Citroen BX 16 Valve Phase 1 (White)
Re: Fault
16v does. Pretty sure other EFI models do too, but its basic at best.
Re: Fault
GTi 8v does too. Kitch's comment probably applicable here as well. :)
Re: Fault
i didnt think OBD/EOBD was around back then on UK petrol cars, it was in Yank land earlier
http://pinoutsguide.com/CarElectronics/ ... nout.shtml" onclick="window.open(this.href);return false;
as far as im aware OBD/EOBD is a 16 pin D socket as in the link above,
do any BX's have one
x 116
Re: Fault
OBD ? No they dont. The GTi has a two pin diagnostic socket for reading out error codes though.
Re: Fault
Andrew your car is a old fashioned diesel, cant see what you would need it?
Stinkwheel
Re: Fault
Post by Stinkwheel »
Modstox257 wrote:Does any model of BX have an EOBD socket ?
What is the fault? (or symptom) you have.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
Modstox257
Re: Fault
Its not for me its for someone i know thats got a 16v and there cars got the ABS light on ?
btw thanks for the replies c:
Andy c:
Re: Fault
ABS ECU is seperate to the engine ECU so it wouldn't store fault codes anyway.
The ABS system is quite basic and easy to fault find the old fashioned way.
Start with checking the fuse, then the wheel sensors at the plugs in turn. Start with the front OS sensor, it nearly always is that one.
