Triple LHM joints, all missing
Thread Bear
Each car, ABS, I have obtained is missing the green three way joint that sits on top of the LHM reservoir with a return and breather pipe in it. Also handy for when one fails on the crossmember. So I now need 4 of them as one cross-member one is very soft, just as they get when about to split in half. I know Pugs use them on some models for the PAS, I think. They supplied them in pairs. Is that a Citroen part or available from another source?
Re: Triple LHM joints, all missing
Still available last year - our local dealer had 5 in stock. Also a similar part used on the Xantia I think.
make one up using a readily available plastic T piece, from most motor factors available in 4/5/6/8/10mm dia and oyher variants, ive used these on the tzd when i replaced the return pipes/breather to the res.
There is a reason a Y piece is used...
I've just used a short stub of fuel hose to join the liquid pipe to the cap. The cap is a loose fit so I figured it could breathe around the join. Doesn't seem to cause any problems omitting the breather pipe.
(ps: a T piece won't interrupt the flow and you'll lose LHM into the wing.)
here is price and part No.'s for the tank lid Y and the front sub frame T in that order
Y
0000527014 3 WAY UNION 4.89 GBP 5.87 GBP 5.87 GBP
T
5451210 RET TUBE SLEEVE 12.65 GBP 15.18 GBP 15.18 GBP
i have made the lid one up from a plastic T and three very short stubs of dead octapussy tentacles,
but i do see Y it should B A Y, as its intended to direct the incoming capillary flow into the tank, rather that allow it to get into the vent pipe,
the reason it did not use a plastic Y piece is it would bring the pipes up against the bonnet to much/tight
Y
T
KevR
I usually do the same as Way2go - never had any problems.
They were readily available on ebay last year with various choices including the orange Xantia ones but not a one available now.
- x 117
I just drill two holes in the lid and push the plastic pipes directly in to them. I thought everyone did this.
As per THIS threadDefender110 wrote:They were readily available on ebay last year with various choices including the orange Xantia ones but not a one available now.
I wonder if sub777w has a couple left, per the /\ thread/link (as I've not seen any posts from them recently) ?
If you do it this way there is a risk that the second pipe could act as a siphon if its dipping into the tank and drain your green blood into the wing. No real need to drill your second hole or insert the pipe.Jaba wrote:I just drill two holes in the lid and push the plastic pipes directly in to them. I thought everyone did this.
Here you go fellow !Thread Bear wrote:Each car, ABS, I have obtained is missing the green three way joint that sits on top of the LHM reservoir with a return and breather pipe in it. Also handy for when one fails on the crossmember. So I now need 4 of them as one cross-member one is very soft, just as they get when about to split in half. I know Pugs use them on some models for the PAS, I think. They supplied them in pairs. Is that a Citroen part or available from another source?
I've found you a GREEN-ONE !
Click on photo for link
