TZD - Turbo (induction) noise
Stinkwheel
Post by Stinkwheel »
Hello Forumers,
Right, im sure most of you know ive taken on Dollywobblers 308,000 mile TZD estate.
He reported some performance issues and an extra noise. I can confirm these.
The performance isnt 'that' much lacking, but the noise it makes is quite unusual. Its got a reasonably loud but not over loud turbo whistle................but what it does before coming on boost properly is almosy 'gurgles' or 'sputters' before getting down to it.
The oil leak is not nearly as bad as id feared, no drips on floor overnight, i believe it is just coming from the rocker cover gasket.
Anyone have any initial ideas from the noises description before i get deeper?
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
x 19
Re: TZD - Turbo (induction) noise
Boost leak is the obvious thing that springs to mind, but I wonder whether oil in the trunking around a suspect join could cause a gurgle/splutter. If that's the cause though, it must only be minor otherwise performance drop-off would be significant.
Contact:
I'd be checking the induction hose to the turbo on the atmospheric side of it
Stinkwheel
docchevron wrote:I'd be checking the induction hose to the turbo on the atmospheric side of it
Thanks Doc.
Sort of what i was thinking myself, just a case of gaining access and having some time !!!
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Contact:
It's an odd sort of rasping noise, first reported by Citro-Geoff about three years ago, when he still had the car. Definitely some sort of minor boost leak. Have you seen how much soot it boots out when you're enjoying yourself? ;)
Stinkwheel
urrr, yes, and so have the people who dissapear behind it :) :)
But seriously there is very little wrong performance wise, just a wee bit down, so it really cant be that serious an issue (i dont think anyway) just a nightmare to get too (ref cramped engine bay)
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Contact:
Aye - it's not too bad. There's a very steep hill around here that the TXD would comfortably (with a run up) pull its way up in fifth. The TZD just wouldn't.
Oilyspanner
Post by Oilyspanner »
I have had turbochargers that were positively raucous, like going down the road in Knight rider :) but none of them failed, interestingly last year SWMBO drove our Xantia into a couple of feet of floodwater, until it stopped :shock:
Naturally after I had finished complimenting her I towed it home and set to, the cylinders were full of water as was all of the inlet trunking and the intercooler, once drained out the engine started first go and actually ran a little better than before which I put down to the water washing the oily guk out of the intercooler, my favourite for boost leaks on the TZD has to be the rubber seal between the intercooler and inlet manifold, also try removing the top engine mount and pull the motor forward to check the inlet manifold is secure and the turbo trunking is intact.
Thread Bear
Post by Thread Bear »
Yes the intercooler rubber has given me a fail once. Found on taking it off to give the matrix a darned good clean out. I did that anyway but the gasket was the real fault. Greatly improved pick up.
x 150
I steamcleaned the intercooler on the green hornet when I got it and found that went better afterwards so I would check to see how clogged it is, it wont helps with the noise but may help pick up.
Stinkwheel
Hi Folks,
Thanks for all the sharing of ideas here.
I did have the intercooler off to just 'have a look' as it were.
The thing was nice and clear and the gasket/seal was intact and doing its job. Further investigation required still.
(although i did manage to do a few other little jobs - between welding the 16Txi)
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
