This time I replaced the brushes, owing to be able to disassemble unit completely this time..all back in and working really nicely now..
Just a quick note that may be of interest to some that the Paris Rhone has an odd design characteristic. Being that if the bushes are very worn or the main motor part circuit is open, then the solenoid will not work too...ie hardwiring the solenoid will give the impression that it too is fubar...
I remember discovering this the first time I pulled the starter and bench tested it..I concluded the solenoid was the problem, and so cleaned it up, reassembled and everything worked (for a short time).. I must have jiggled the brushes giving them a tad more life..
So yeah...trick for new players there!!
Chow
