Wanted - Sunroof seal
kbami8txd
Post by kbami8txd »
Hi - does anyone know where I can get new sunroof seal ? (the rubber / felt that goes round the glass ) Thanks
Re: Wanted - Sunroof seal
you are aware this is only a draft felt as is not intended to stop water getting past,
if you are getting water in the car it probably just requires the drain tubes blowing clear/through with compressed air,
as they get a build up of crap which blocks them then water over fills the chanel into the car
The XM sunroof seal is still available from main stealers. If no luck, try a company like Webasto.
kbami8txd
Post by kbami8txd »
Thanks
no water leaks ,
