engine doesn't stop
rugmuncher
- My Cars: BX 1.4 RE, BX TZD TURBO, BX TZD Turbo, BX TXI, BX TZD TURBO
engine doesn't stop
Where is the fuel cut off solenoid on my BX TZD Turbo? The engine doesn't stop when I switch off the ignition! Help!
Re: engine doesn't stop
Do you know which make pump you have, as it depends.
TizzyD
- x 10
I had the same issue, FCF helped me work out what pump I have
http://www.frenchcarforum.co.uk/forum/v ... op#p170982" onclick="window.open(this.href);return false;
He's sorted it in one of the other 3 threads he started on the same subject!
