Help!
- rugmuncher
- My Cars: BX 1.4 RE, BX TZD TURBO, BX TZD Turbo, BX TXI, BX TZD TURBO
Help!
Where is the fuel cut off solenoid on my BX TZD Turbo? The engine doesn't stop when I switch off the ignition! Help!
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: Help!
If it won't stop when you turn off ign then the chances are the stop solenoid is dud, reasonably common. Best way to stop is by using the stop lever on the pump, but you could purposefully stall it. Worth checking the wiring and continuity before replacing the stop solenoid
- rugmuncher
Re: Help!
Yea thanx but I have a spare engine and pump so I'd just like to change the solenoid. Which unit is it? The one on the side of the pump or the one above the pipes to the cylinders?
- rugmuncher
Re: Help!
Thanx all. I've fixed it.
