This could be a bit cheeky
- sleepy0905
But you dont know without trying.
I am after a 1.9/1.7 non turbo diesel angine and box very very cheap and as near to Lincoln as possible as i have virtually no free cash and only a very small crappy trailer with nackered lights that i can borrow.
- ken newbold
- sleepy0905
- ken newbold
- ken newbold
I've had a word with a friend of mine and he says he has a low mileage 17d engine currently still in a C15. The good news is he says he could get it out for you in a couple of hours and it's only 12 miles from you.
The bad news is he wants £70 for it, which would probably include the gearbox and also you'd need to change the camshaft as it's in a C15 with a flange mounted vacuum pump.
- sleepy0905
Thanks ken but thats a bit steep for me especially as there is the cost of changing the camshaft as well i am starting to think that this idea isnt going to work as i have very little funds available i may have to consider either selling the one i have to raise the cash to get a replacement or just drive this one into the ground and hope some funds come available to do an engine swop.
- ken newbold
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 79
Just add the cam from one of my heads, there easy to do!
Just got a new job, but i need to come over lincoln way (ish) to pick up various bits so theres a possibility i might be able to run an engine over if it needs collecting from this side of the isle, though i may well need a jump start by the time i get to you! Bloody alternator!
- ken newbold
Sounds like a plan to me! Are you bringing Sleepy`s car and chnagine it all here or just removing my engine and box and taking it back with you? Makes no difference btw, just curious!
BTW Mark, I would have thought 1.7 n/a diesels were naff in BX`s until I owned one. Went like a rocket for what it was and Vanny`s mate will bear testament to that as he`s still smoking around in it.
Vauxhall apologist.
- sleepy0905
