Could those of you in the know also look this part number up to see if it is available. It is number 2 in the picture. Thanks.
91507684
RP96181359
Thermostat housing gasket. Now with picture. Anybody please?
ghaddon1701
Re: Thermostat housing gasket. Now with picture. Anybody ple
Not sure if Citroen have it, but it may be worth checking with GSF - I'm pretty sure it's available as part of a kit at least.
service citroen and pug service box are down at the mo, s o i cant look at availability yet,
but i think i have some of these NOS,
i will check later
or you can make one out of a cereal box
i will check later
gasket paper, lay it on the side of the body and rub over it with some chalk and it will give you a pattern of your gasket, then carefully cut it out, the small holes can be punched out with a hole punch. this should get you out of trouble.
this looks like the gasket on service citroen but has a different part No. now
0000134008 HOUSING SEAL 1.20 GBP 1.44 GBP 1.44 GBP
or if you dont want the expense of a new one use as i said earlier,
place it over the housing and tap all the way round it with a ball peen hammer, this will cut the card exactly were you want it
TIP: if doing this go round the internal walls first and use a ball bearing tapped with the hammer to cut the holes.citronut wrote:
