Rear Arm bearings.
- Stinkwheel
Rear Arm bearings.
Are estate rear arm bearing kits the same as hatchback ones please?
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- mat_fenwick
- x 19
- Stinkwheel
Re: Rear Arm bearings.
mat_fenwick wrote:Yes.
Ta,
I thought so, but best to be sure
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Same as C15 as well, aren't they? And Xantia?
- Stinkwheel
I believe so Kevin, yes.
Which is good for mis advertised items
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Yep, that was my thinking... !
If you want genuine SKF kits, they do crop up on Leboncoin quite often.
mds141 wrote:If you want genuine SKF kits, they do crop up on Leboncoin quite often.
These were available off the shelf from GSF last year.
- Tim Leech
- x 141
try Malcolm Lockwood aswell. nice chap and very fair.
http://www.citraulix.com/" onclick="window.open(this.href);return false;
65 Peugeot Boxer work van 280k - x 136
got mine from camberley auto factors 2 kits £70 skf too. tho not a stock item they got them in for me at cost + 20%.
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Jay had the actual bearing part number. If the rest is ok you could save a few pounds by buying the bearings only. Either pm him mate or search on here, Jay is good at documenting such info.
- mat_fenwick
- x 19
I did just that, so i'll try and dig out the pat number if Jay doesn't see this. Cost was around a tenner for the two bearings, but I had to buy the seal from GSF as I didn't have reliable dimensions I could search for. I.e. the old seal was knackered. It was £4 posted I think for a couple of seals though, so certainly a cheaper way to do the job.
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 79
Is there a link between Citraulix and MC Lockwood?Tim Leech wrote:try Malcolm Lockwood aswell. nice chap and very fair.
http://www.mlockwood.org.uk/" onclick="window.open(this.href);return false;
Other than being in the same area?
different phone No.Vanny wrote:Is there a link between Citraulix and MC Lockwood?Tim Leech wrote:try Malcolm Lockwood aswell. nice chap and very fair.
- Stinkwheel
Thanks for all the info and help folks.
I got a bit of a bargain i think. 2 full kits from a factors through e-bay with decent enough timken bearings and all bits and bobs, 2 x kits for 40 quid postage included. Im pleased with that
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
