gti wheels X 5 on the bay s/b £25
im sure someone will add the link..
Re: gti wheels X 5 on the bay s/b £25
I have enquired as I don't live too far away.
Maybe worth a punt.
Any issues with fitting 6J's to a 8v GTI?
Maybe worth a punt.
1990 Black BX GTI
In a nutshell, NO !Pogo wrote:I have enquired as I don't live too far away.
Maybe worth a punt.
Good luck if you can get therm for £25 !
- x 88
I reckon the silver one could be a 5.5J GTi rim. Mis-matched centre caps and corroded rims too by the look of it. Still a bargain at £25 though!
1990(H) 16Valve (Rouge Furio)
According to the seller, all 5 are 6J rims.
Someone has already had a bid, but may still give it a bash
1990 Black BX GTI
Would these fit on my '92 16TXS?
- x 88
Yeah they'll fit all BXs, even the estates and mk1 with a spot of tweaking to the rear arches.
If only the one bid was placed, but listing ended this evening showing as Sold for £87 !Kitch wrote:I reckon the silver one could be a 5.5J GTi rim. Mis-matched centre caps and corroded rims too by the look of it. Still a bargain at £25 though!
Still a reasonable/fair price for the seller/buyer !
Is the new a owner of them a forum member ?
I am indeed! Picked them up today, and am going to give them a good clean then fit them.
Well doneswinegull wrote:I am indeed! Picked them up today, and am going to give them a good clean then fit them.
Does the wheel-set come with the correct type (Flat faced washer and thread length) which Citroen used for this type of Alloy wheel, as the listing had no mention of them ?
As some folks have used ones from Pugs (which are no good) see THIS thread for more info !
If the wheel-set came with the stud-bolts great, if not you'll need to source the correct type (If this is the case, PM me I may be able to help) !
