Hi - just checking to see if there has been any change in getting over problems of ageing rubber hydraulic pipes. Assume that there is no supply of new octopuses ?
What are folks doing to get over leaks etc?
Richard
hydraulic - octopus/spider
- Tim Leech
- x 150
Re: hydraulic - octopus/spider
Yes they are still available new.
Just ordered a couple from my local stealer only to be rang yesterday to say that they were on back order. I hope this isnt the beginning of the end of them!!
Thanks Tim/Andy
I checked with our dealer and their system is showing parts available later next week. Mind you if that is based on a supplier's delivery date I hope they factored in the French summer hols!
One more query: looking back at previous queries on the subject there seem to be three rubber part nos:
960 30258 Main octopus £ 44.27
960 56235 ??????????? £ 33.05
96119048 Pipes from LHM tank ? £ 61.29 ( all prices VAT)
What is the 960 56235 part
its so long ago that I changed these parts I can`t re call if you normally need both parts ( assuming pipes from tank are OK)
i might get quick at fitting them at this rate AndyMothman wrote:Just ordered a couple from my local stealer
Quick enough for me bud, it was like watching a masterclass when you did it.
On my 96056235 its called a faisceau retour doseur whatever that means and all you need if the octopus fails is the 258 part, dont need to fit the others unless they have failed too.richg wrote:One more query: looking back at previous queries on the subject there seem to be three rubber part nos:
Octopus as of today now available again.
goooogly translate sayMothman wrote: On my 96056235 its called a faisceau retour doseur whatever that means
return beam doser
