My front fog lamps are playing up! The problem is electrical conductivity in the lamp units themselves. Wrapping & soldering wires to the spring retainers is only a short term fix as poor earthing conductivity here overheats the bulbs.
Now it seems to me that for the short time the fog lights can be used it would be better & considerably more useful to replace them with driving lights as they could be employed regularly on the "white" roads round here!
Any suggestions on type & availability of driving lights that would fit the existing mounts? (along with approximate prices.) Also are there any candidate cars containing standard suitable fitments likely to be found at the scrappy?
Driving Lights
Driving Lights
Stewart (oily!)
I have some nice yellow driving lamps which fitted into the original TZD black plastic mounts with very little difficulty, they were fitted amongst others to Renault 19s,espce, 21 etc all I needed to do was to drill another hole in the black mount and get some new bolts (I used stainless allen bolts/nuts/washers) You may need to take your battery drill to the scrapyard as the fastenings even though made of brass seem to always be seized. Thats them on my avatar!
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
- x 27
I feel the BX's low-down (weak by today's standards) 'fog' lights are already suitable as 'driving lights'. I use them along unlit country lanes - they're good at giving that little extra 'width' to the illuminated area - no more distance though. I did look at replacements for a previous BX GTI and found some in Halfords that would have fit the apertures in the bumper. I think they were Ring ones. I have seen Hella ones fitted to another BX too. I'm sure there'll be something out there - it's a case of making a card template for the size and carrying it around with you!
These are what I have on my BX:
http://www.motormania.co.uk/product_det ... tDescID=80
They fit the apartures nicely and mean you can have your cake and eat it! However, I find the location of the driving lights a little on the low side but they do help, especially with 100w main beam bulbs (I do a lot of driving on unlit Welsh roads now!)
Hi Mat, looks interesting! Can both beams be run together or is it switched to Fog or Spot only?
I was thinking that probably a rewire is necessary on using driving lights so they were connected into the main beam circuit. This will then switch them out each time its necessary to dip the lights.
rob-bx16v
we have yellw renault clio foglamps on our bx gti pinched from my brothers old clio rt they work well.
bx16v p2 k reg red
bx16v p2 j reg green
bx gti 8v h reg blue
escort rs turbo g reg red
bx16v p2 k reg red
ssray
I used 2 relays, fed directly from the battery (fused). One powers the driving lights whilst on main beam, the other powers the fog lamps ( I used the original switch) You will have the wiring already present for the fog lights though.
I had a hole in the steel panel that was already drilled - I assume that the original lights use this as a fixing. If you want I will send you a picture if you let me know your email address.
- x 27
