Quite unexpectedly it seems Kermit and I might have found a BX that suits our needs and isn't too far away/expensive. We plan to travel to where the BX is and do a repair that means it can, once again be driven. Some might realise from Facebook that this is an estate with a broken clutch pedal.
Any advice and information would be useful, chaps!
BX Repair advice.
- Philip Chidlow
- x 25
BX Repair advice.
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: BX Repair advice.
Replace clutch pedal? Seriously, what else did you want anyone to say!
What lump is In it?
What lump is In it?
- Philip Chidlow
- x 25
lol! Replace or repair is the plan. I suppose I should've been a bit more precise. Any tips for removing and replacing a pedal box?
It's a n/a 1.9 diesel BTW.
65 Peugeot Boxer work van 280k - x 136
remove driver seat makes access a lot easier 2 nuts and 2 hex key hold the pedal box in thhey are loctited, fit a new clutch cable whilst its all out ensure cable collars are lined up and take a spare throttle cable plastic clip, fairly easy should take an hour or so, take note of clutch cable routing. removing the top engine mount will give better access as the engine can be tilted forward a bit as access is fairly limited, good luck
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Unless you have access to a welder, then you'll need to replace with a good unit.
Not a lot of fun getting that 'securing clip thing' to keep the clutch cable sheath secured properly.
Never thought of removing the the front seat but that would seem possibly the best tip you'll get!
Be sure to adjust the clutch pedal travel correctly!
- Stinkwheel
Is it cable or pedal?
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- Philip Chidlow
- x 25
Now, it would seem this isn't going to happen. Not an easy decision given the BX in question, but as per my blog, different priorities have made themselves heard.
- Stinkwheel
Phil, can you pass the guy my email or get him to contact charlotte who posted on his post on the ccc Facebook page ? Think we can save this one maybe.
many thanks.
many thanks.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
