WANTED: BX 16v Ph2 Hydraulic pipe - Pump to FDV - 96034027
x 103
My pump to FDV main steel line has just fractured on the valver. Managed to limp it home, just, only leaks when the PR kicks in, but my how it leaks!
Its a 6.35mm pipe 525mm long (960340270, it is not the same as the 565mm Diesel supply pipe, though i don't know if the diesel one (95 596 564) might bodge in if needed (its the only one not NFP at citroen).
Cash waiting for new or old pipe!
Stinkwheel
Re: WANTED: BX 16v Ph2 Hydraulic pipe - Pump to FDV - 960340
Post by Stinkwheel »
Try the 14 tu engine pipe number, they are still available (or were 4 months ago) ??
maybe bodge into shape? I cant remember the shape of a 16v one in afraid, so its a guesstimate.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
JayW
x 13
Post by JayW »
I have spares but can't get hold of them until just before me wedding, but if you're still desperate then let me know!
How about Rich?
x 103
Have contacted the Doc and the good Mr Kitch, hopefully they might be able to help.
Using a 14TU pipe is a nice idea, though they are showing as NFP, and are over DOUBLE the length of the valver one. I can't see how i could bodge it into place without significantly kinking the pipe.
Have i ever told anyone how much i HATE the FDV? Seriously considering going back to a twin output pump setup!
x 138
Post by rutter123 »
if u measure it plaedies can supply one made up ready to fit, one for my t/d was about £15 and delivered next day.
x 103
Genius, plaedies, totally forgot about them, but you're damn right, it should be something even they are capable of.
You've got one winging it's way to you at the moment, should be there tomorrow. I didn't get a chance to check it against mine, but I reckon it's probably right.
x 103
Mwah ha ha ha
Cheers Kitch, very much appreciated (by me and the electricians who can't currently get in the garage!)
