Hi Everyone
Can anyone help me out with a replacement upper speedo cable for my BX service van and possibly the accumulator on the gearbox? Mine's got a very slight weep. It's nearly on the road. I've made a few subtle changes to her but nothing that can't be put back to standard.
Thanks in advance
Kev
Upper speedo cable
Re: Upper speedo cable
Hi Kev !
Re:- 'Upper Speedo Cable' I think that request/want will be a tall order to fill as the 'upper section' are NLA at the main-dealer's unless your lucky enough to source a NOS from somewhere ?
Also try Jaba, Kitch or Bandit [On this Forum] who are breaking BX's, my last good used one went to a forum member approx. a year ago !
If you have no luck, you may need to go down the ONE-PIECE route !
With regard to the Accumulator, I take it your just after a Sphere of 62 Bar which are easy enough to buy locally from a good motor-factors or from CarParts-4LESS , GSF !
Good luck !
Good luck !
