As we all know these are hard if not imposible to source now.... Well I need two for my 4x4 as I had to wreck the originals during refurbishment (I stripped everything down for sandblasting and coating etc...)
The 4x4 used ATE ones that were handed ie lh and rh whereas the normal bx's use a common one.
They all sit in the radius arm hole and make themselves quite at home by corroding in......
Anyway, to make the 4x4 100% i am happy to pay full dealer price for any new ones i can source - that is usually more than you can buy a whole car for, i know - but needs must
Part numbers are;
96016397
96019964
91537913 std bx
Any help appreciated as i thought a supplier in germany could help but they have let me down and i want to bring her up to the nec in november
Got the original items from Spain in the end - the standard BX sensor does not fit the 4x4, the sensor end is actually different in that the standard BX sensor is 90 degrees to the notched ABS ring whereas on the 4x4 it is in line, so a totally different sensor....
