Hi, if anyone has any of these (new or similar condition) I would like to buy them, cheers
OE-Nr: 26212599
OE-Nr: 7905026881
OE-Nr: 95568527
OE-Nr: 95589173
OE-Nr: 96016397
OE-Nr: 96043551
OE-Nr: 96061241
OE-Nr: 96079136
OE-Nr: 96126771
Thanks
Citroen OE Items required please
IOWBX
- My Cars: 61 Hillman Minx
65 Sunbeam Alpine
65 Ford F250 pickup
82 Lotus Eclat
90 Renault 5
90 Rover Metro GTi 16v - x 3
I like older cars… I love Citroens
Need a BX
Need a BX
Stinkwheel
Re: Citroen OE Items required please
It would help some of us to tell us what the part numbers equate too. I certainly have some nos bits that ive no idea the actual Citroen part numbers
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
I have tons of parts with numbers on them but ime sorry i cant help as i dont carry all the numbers around in my head and am not going to wade through them to find they are not the ones you want.
However, Malcolm
may be able to point a finger in the right direction. Sorry Malcolm, just couldnt help it!!
However, Malcolm
26212599= the pivot bolt for the rear height actuator lever on rear axle cross beam,
which on all the ones i have worked on is just a nut and bolt ( nout special )
7905026881= small tight angeld rubber pipe for petrol tank vent ( at tank plastic pipe plugs into )
95568527= rear height actuator lever on rear axle cross beam
95589173= gate for height lever in car under center console
96016397= left rear ABS sensor
96043551= O/S rear suspension cylinder feed pipe
96061241= nylon bush front to rear height lever runs in on front sub frame
96061241= duplicated as / \
96126771= rear brake front to rear feed pipe
owz that for fingering Andy
Des Smith
I'm trying desperately to be unimpressed, but I've failed. That's impressive.
Xsara Forte 1.4i 2000
Kawasaki GPz550A4 1987
And all typed out with one finger Malcolm. Well done. I too am impressed!!
IOWBX
65 Sunbeam Alpine
65 Ford F250 pickup
82 Lotus Eclat
90 Renault 5
I say, well done - yes thats what im after please if anybody has these i would be very grateful if i could buy them
The desperate items are the abs sensors, fuel tank breather tube and the suspension pipe - money waiting....
Need a BX
Need a BX
Have you tried a dealer search? They like it when you give the part numbers as it makes life easier! Worth getting them to check other dealer's stock if NLA - I've been told "Sorry mate, NLA" only for them to find they had the part themselves on the shelf! Replacement cupro-nickel pipes will be available from Pliedes if originality is not crucial.
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Are they urgent? Hope notcitronut wrote:26212599= the pivot bolt for the rear height actuator lever on rear axle cross beam,
95568527= rear height actuator lever on rear axle cross beam: yes but used
95589173= gate for height lever in car under centre console: yes but used
96043551= O/S rear suspension cylinder feed pipe: yes but used, condition tbc
96061241= nylon bush front to rear height lever runs in on front sub frame: still don't know what this is, will check
96126771= rear brake front to rear feed pipe: possibly and new, checking it's the right one may be tricky
IOWBX
65 Sunbeam Alpine
65 Ford F250 pickup
82 Lotus Eclat
90 Renault 5
Thanks guys, urgency only in as much as i would like to take it to nec in nov and then a 2000 mile trip via scotland which is booked and paid for, alternative is buy another?? TZD or the blue 4x4 maybe or use something else in the fleet..... but ideally the red 4x4 as this would be the first outing since ownership off here, about two years i think but it should now last another 20.... its a keeper as i will never recoup whats been spent...
The abs sensors and the suspension pipe are the main items, i can make do without the rest for now....
Will try some other dealers and also plaeides who have supplied a fair bit of stuff already...
Look forward to Malcolm's outcome on the items mentioned , thank you
Need a BX
Need a BX
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
I have answered, but not clearly. See my replies after the : in the quote
