radiator cap.
really?
radiator cap.
how many lbs of pressure should i have on the td cap? found som nice looking fahler items on the bay (again) and they have a range of pressures.(7,10,13,15,20) mine has a crack in the presumably brass disc above the spring and i just heard it leaking air as the car cooled after an oil change and pump belt tighten, so it definately needs a new one. might also explain the running a tad warmer? no gunge just a bluish evaporated coolant looking powder around the outside. cheers.
Thread Bear
Re: radiator cap.
All my rad caps are thus. I queried it at Stratty. Seems that these fail regularly, so I assume they are crap. I was waiting till I went to the scrappy to get an older version made by people who drink Irn Bru. The cars seem to run OK on ithe failed ones and with Turbo it stops the rad weeping as it is not under as much pressure. Such is running a half buggered car that broken bits are better than perfect bits!
