Does anyone know if these pumps mounted on the side near the bottom of the tank are still available ?
Best wishes
Richard
Washer pumps for Mk 11s
richg
Stinkwheel
Re: Washer pumps for Mk 11s
I expect they are, as i believe they used the same ones on CX's BX's AX's and some Xantias.
Although if they are not then most car accessory shops do one that can be fitted inline.
Failing that find a scrap C15 in a scrap yard, these used to be the desired upgrade for 2CV's and Dyane's
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
richg
Thanks - yes they are still available. £17.00 plus the VAT. Dearer than an in- line but you nice if you like to keep things originals
some of the better independant factors stock a range of pumps that will replace originals, although none of the chains seem to.
richg
Thanks - I`ve fitted the Citroen part now ( and the seal just in case) but might try to match the old pump with a cheaper version!.
the OE pimp is still showing as available on service citroen
0000643466 WDW WASHER PUMP 17.03 GBP 20.44 GBP 20.44 GBP
the gromit comes separately
0000643445 WASH PUMP SEAL 2.98 GBP 3.58 GBP 3.58 GBP
you can always aim the pump part No. at GSF to see if they do a compatible one for less dosh
