wanted rev counter for a diesel bx veglia
for the tgd, in place of the dead clock. the tdc sensor is already fitted on the bellhousing, so i guess a small bit of loom will be req too. instruments are veglia.
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: wanted rev counter for a diesel bx veglia
How soon do you need it? I can certainly help pronto with the rev counter but investigating the loom might delay me a bit. What have you got already? Just the sensor? Is there the wiring in the engine bay?
hi bx bandit, no real urgency as i dont expect it to on the road this year but i have the pod out at mo to replace some backlight bulbs and remove said duff clock, etc so to save doin the job twice.....
as far as i can see only the tdc sensor is fitted (with a 2/3? pin connector), cant see any other obvious loom or spare plugs, as this is a 1.9n/a the engine bay loom is pretty basic, while not a necessity the further part of the loom ( i seem to recall the tzd rev counter has its own separate supply lead, yellow plug?) would be good but failing that make a bit of loom up.
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Ok, I'll have a look at loom related stuff over the next couple of weeks. Didn't I also promise you something else? Stainless bumper trims + clips?
yes u did some time ago.
