Looking back on topics it would seem it is the top or dash end of the double cable that tends to fail. Having parted mine into halves while visiting the area for the LHM pump I would think that will be the case here as the lower inner is solidly located with a little free play movement.
I assume you cannot strip out the upper inner and replace without disturbing the dash board etc. Will not work if the stub end is bust off anyway, I guess.
I note also that the speedo heads can fail and that the actual connection to the head is iffy as well.
Are the cables on RHD all the same? Swapping TZD for TZD at the moment, so should be identical.
Sounds like a bit of a weak set up all round really. Already I do not like the angle the cable takes to go through the bulkhead. Larger the radius the better for the cable. If the rest as as poorly done could be mod time out of my amazing box of misc speedo cables. Only trouble is no one knows what half of them are off. Had quite a few hits from folk with really rare cars with this old stock. DKW, Lloyd, Simca Coupe, Goggo/Isar 700, DAF 32, an obscure Lotus etc.
Speedo cable issues
Thread Bear
Speedo cable issues
Re: Speedo cable issues
All top cables are the same just the bottom cables vary depending on engine fitment.
ghaddon1701
They are easy to thread from the back of the dash pod down through the back of the dashboard if you remove the glovebox. The problem with them is the squares in the cable are plastic and they wear out and make the speedo needle wobble. But no it doesn't help that they had to thread it from the nearside to the offside for us Brits.
Thread Bear
Ah, Plastic. I see. Probably the sort resistant to a repair. Could be a little frustrating but I guess its lasted its design life. Will have a fiddle.
ghaddon1701 wrote:But no it doesn't help that they had to thread it from the nearside to the offside for us Brits.
This happened to an Englishman in France who was totally
The French policeman stops his car and asks the gentleman if he has been drinking.
With great difficulty, the Englishman admits that he has been drinking all day, that his daughter got married in the morning to a French man, and that he drank champagne and a few bottles of wine at the reception and a few glasses of single malt afterwards. Quite upset, the policeman proceeds to an alcotest and asks the Englishman if he knows why he has just been arrested.
With humor, the Englishman answers: And do you know that this is a British car and that my wife is driving... on the right side???
- x 60
The complete speedo cables on the BX 4x4's are different, (or on mine anyway) it has a solid bottom part that goes from the transfer box to the bulkhead & the bit that screws the 2 together is the opposite way about on the 4x4 cable compared to a standard cable.Defender110 wrote:All top cables are the same just the bottom cables vary depending on engine fitment.
