heating fan and switch
cacaolat
Post by cacaolat »
recently my Bx's heating fan has stopped working for most of the time, but sometimes it still decides to come on, which makes me think that the motor is ok but the contacts may have a problem.
Also the turn dial for the warm and cold is stuck.
Are this easy things to fix ?
Re: heating fan and switch
The temperature issue is probably a stuck tap - I've not done it myself, but I gather it's a fiddly job.
I think there's also a thread in the FAQ section detailing a mod that may solve the blower problem.
Tinkley
Post by Tinkley »
It - blower on/off can be the rheostat under/behind the control knobs. Mat's got some other points of weakness that are also worth pursuing.
x 138
Post by rutter123 »
carbon brushes on the blower motor can wear worth checking as they also stick, worth a good clean and check earth to blower motor as these corrode. usual common problems with these blower motors.
Another thing I've just thought of - there's a connector just in front of the blower under the bonnet that sometimes gives trouble - I sometimes have to give it a wiggle on Timex.
electrokid
Post by electrokid »
Most likely worn brushes on the motor - no longer available AFAIK so find some brushes from a BATTERY operated power tool which are bigger and file them to fit the motor. Don't use brushes from AC mains equipment - they are a different mix and will wear out quickly. Also wiggle connectors to clean as it all gets a bit damp in that area.
2002 C5 HDi SX estate
cacaolat
Post by cacaolat »
Thank you all for the replies, so far I have tried to wiggle the connectors and it seemed to work for a few hours but now I have to try some more. it takes so long to get round to it because of Lack of time and no garage, so evenings are not good for this.
Thread Bear
Post by Thread Bear »
Having pulled all the blower and control system completely apart just recently, there is nothing that is inaccessible like on some cars. The Citroen BX DIY item is helpful to a point. Certainly a good clean is not going to harm, and it picks out those points. The dash switch is not clever but again it can be cleaned - the PCB board with care to not remove the surface. It is is quite simple for the plastic disc to not be pushed home, stay home, or supply insufficient pressure to the small brass double contact placed under it. Heating the disc with steam from a kettle can re-profile it to do so, but not overly, as if the PCB board contact coatings are worn through, its an end game till another can by found, or you make a replacement. In my case I think the issue was, in fact, a corroded Blower PCB insert, which demounts from the back of the blower, where the four pin block connector goes. The blower assembly is not difficult to get out once the wiper nut, pressed in grill and plastic cover are out of the way. Three 10mm, remove the press fit domed inlet cover and two possidrive screws on a steel bracket, and it can be wriggled free. The motor can be tested exclusive of everything else quite simply, so soon eliminated as the problem if it works at speed and then loaded to check the power is consistent all rotation. You do not need to remove the blower to test it but you do to clean it properly. My original did not. I suspect its repairable but not making good contacts at parts of the commutator. So stop on a duff bit and no motor. Stop on a live bit it would work. As it turned out only part of my prob.
Half the task is inside the car so split into chunks you could do this over a few evenings since the car drives with most of this stuff hanging out or detached in the kitchen! You rather need a blower now the cold and damp is here.
