Pogo wrote:citronut wrote:
it is showing as NFP and they are not handed
NFP? does that mean I can order some from Citroen?
NFP =
'No Further Production' unless you can get your local main Citroen dealer to check if any one has some lying on a shelf some where just gathering dust ?
RxBX wrote:.............................
Are you after a pair or just one-side, as I
may have one or possibly a pair available,
I'll take a look in my spares stash for you tomorrow and PM you (If I find something)
I checked out my spares stash today,
sorry no luck (they may have got used in the past, but I can't remember for sure)
For a temporary fix (just to get it thro' the MOT) , cut the bad/rusted pipe pieces out and extend them with additional straight pieces of rubber or silicone pipe with an internal copper pipe sleeve to the rubber strut-return pipes and strap both of the temporary pipes together with some cable ties for additional support to keep them away from the inner-side of the wheel/tyre !
Obviously the MOT station are perhaps not familiar with Citroen's and are not aware that these pipes have no significant pressure (Being a vent/return) so there being over cautious, if there were no actual leaks IMHO surely just an advisory would have sufficed in this case ?
Now if they were the brake pipes or HP suspension feed pipes, that would be understandable to receive a failure if those are severely corroded !
The following
THREAD may be of help if your going down a temporary fix method using an extended tubing and sleeving method !
Good luck with a finding some good S/H or new ones !
