My 19Tri has always had a rough idle since I got it and occasionally stalled. The engine malfunction light would show on over run if coasting down a longer hill.
Checking for error codes showed an O2 sensor problem which always returned after I cleared it.
Today I was searching for air leaks in the tubing between the intake manifold throttle and the air flow sensor but it all seemed OK except for a slightly loose oil filler cap. I wrapped it in sticky tape and found an immediate improvement so a $3 O ring was all it took. Much smoother and more stable idle and no error light on over run. I'll clear the codes again see if they return.
I am amazed at the difference as the possible air leakage must have been only small. It certainly looks like I have stumbled on the problem.
$3 injection tune up
michaelr
Michael, Sydney, Australia
BX19TRI Automatic
DS23 Pallas
BX19TRI Automatic
DS23 Pallas
Thread Bear
Re: $3 injection tune up
The BX angels have nipped on Quantas for a holiday. Great to beat the odds, 'innit?
B-Hive
michaelr wrote:My 19Tri has always had a rough idle since I got it and occasionally stalled. The engine malfunction light would show on over run if coasting down a longer hill.
I realise that it's a month later..(viewing forums less often) but good find Michael ..these little parcels of info can be very handy later..
I still must get up to visit you some time..i have just graduated uni so bit of time on my hands now..(up to 6 cars!!) would be good to hit the beach. u still live at manly?
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX TRS mk1 auto... SOLD
90 BX TRi..parts....cubed
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
michaelr
Hi 2B, congrats on the graduation!2BXORNOT2BX wrote: I realise that it's a month later..(viewing forums less often) but good find Michael ..these little parcels of info can be very handy later..
A trip to Sydney's northern beaches is always a good idea
I will be away over Christmas /New year.
BX19TRI Automatic
DS23 Pallas
BX19TRI Automatic
DS23 Pallas
air leaks on petrol bx's seem rife, i have not long replaced all seals and rubbers on my gti 8v re-clamped and made up some new breather pipes, next job is clean the airflow meter pick ups, but it did make a difference, the idle is now rock solid and the car starts a lot easier with a nice steady cold idle too.
