quick question - XUD7 cambelt tensioner
Just a quickie - I assume that the cambelt tensioner for an XUD7 engine will be the same whatever vehicle it's in?
Re: quick question - XUD7 cambelt tensioner
the tensioner fits these models in an all families search on service citroen
1 document(s) found for C15
2 document(s) found for ZX
3 document(s) found for BX
1 document(s) found for XANTIA
1 document(s) found for C25
the idler likewise
all XUD engine
the idler likewise
all XUD engine
Thanks, I thought that would be the case but also thought I'd better check - C15D cambelt kits are listed at £40 less than BX 17RD ones!
But the later C15s had the (XUD based) DW8 engine, which may or may not have the same tensioners. Best to check dates before buying.
Nasty DW8's
It was the one listed for 80's and 90's models I was looking at thanks.
the DW8 is another kettle of fish all together which has a completely different arangment/tensioner set up,
the XUD has 136 teeth cam belt the DW8 140,
Thanks for the advice folks - this is what I've found...
http://www.ebay.co.uk/itm/380425731273? ... 1423.l2649" onclick="window.open(this.href);return false;
