Evening all, well here I am again asking for help.
The problem today is the relay box needs replacing. Is this a cheap and easy fix does anyone know or a horrible job?
Any help greatly appreciated.
Relay box
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
Re: Relay box
what is a 'relay box'? Do you mean the fuse board? In which case its a relatively straight forward job, but i've never ever seen one fail, even heavily drenched they tend to dry out and work again.
Unless of course you mean the plastic 'hat' that covers the relays in the scuttle (near the front windscreen wiper motor)
Re: Relay box
It's also on Facebook, and it turns out his garage mean the glowplug relay. But they're also blaming that for all the warning lights coming on randomly, so I'd be somewhat suspicious of their diagnosis...
electrokid
Re: Relay box
It does sound like "inappropriate guesswork"so I'd be somewhat suspicious of their diagnosis...
If it does have something to do with the glowplug box then I'd suggest the first step would be to look at the earthing / grounding connections. The negative lead from the battery should be securely attached and connected to both the bodywork and the engine. Then check the battery connections themselves to make sure they are tight.
2002 C5 HDi SX estate
