Cam oil seal distributor end 1.6 petrol
Tinkley
Post by Tinkley »
Anyone got the seal specification for the above mentioned part?. B2C engine and the only real leak is from under the distributor. Tried searching but no joy on exact sizeing.
I assume it is an off the shelf seal, not a special so I might as well get it from a local bearing/seal factor, unless Citroen are unusually cheap.. :lol:
Re: Cam oil seal distributor end 1.6 petrol
http://www.rockauto.co.uk/catalog/x,car ... type,10063" onclick="window.open(this.href);return false;
http://www.rockauto.co.uk/catalog/morei ... &cc=914310" onclick="window.open(this.href);return false;
Tinkley
Post by Tinkley »
Thanks Defender, that is exactly what I needed. Now I hope to have a nearly dry unit after that has been fitted!. I believe it is actually quite a common failure on the petrol units. Still can't moan too much as it sat for 4 years in the other car outside and worked just fine after flushing.
isnt this seal just an O ring fitted the the bottom of the DIZZY
here is price and part No. for the O ring on a
BOSCH 0237009617
1,580L AND CARBURETTOR SINCE RPO 04158
0000593360 O-RING 0.95 GBP 1.14 GBP 1.14 GBP
and its the same one on the DUCELLIER DIZZY
it only gives the diameter which is 36.5mm
Tinkley
Post by Tinkley »
Thanks Malcolm, I suppose if I take of the DIZZY of the old extracted engine I'll find out :lol:
It is a light but persistent weep of clean engine oil. Both engines have had this but the tired one leaks on other seals and joints too. I do know I've got the Bosch DIZZY cap and as there are 2 types of each ie Ducellier and Bosch it is fun tracking the right one down. It does need a new cap and arm because I don't like doing much more than 30k with them as there is always wear/pitting on the internal contact faces in my experience.
seems there is only one O ring across both makes of DIZZY
