Wanted 16v LHM pump
Modstox257
Wanted 16v LHM pump
Post by Modstox257 »
Dose anybody have one ? And are all the LHM pumps the same for the petrols or are they all different for each model ?
Andy c:
1992 Citroen BX Hatchback 1.9D (Red) FOR SALE !
1993 Vauxhall Nova Van 1.5D (Blue)
1977 Mini Clubman 1275GT (Brown/Blue ''Restoration'')
1968 Ford Anglia Saloon Deluxe (Blue ''Restoration'')
1989 Volvo 240 GL Saloon 2.0L non turbo (Blue)
1989 Citroen BX 16 Valve Phase 1 (White)
RobC
My Cars: 1991 Citroen BX 16v
x 30
Re: Wanted 16v LHM pump
Post by RobC »
They're different for the 16v because it's driven off the cam pulley (as opposed to the crank pulley on other petrol models), and indeed there are apparently two kinds of pump for the 16v. It changed around 1989 I believe (can anyone confirm?) But I think all 16v ones are interchangeable, as long as you get the right mounting bracket and belt.
1991 Citroen BX 16v
Modstox257
Mines 1989 Il try and get a picture of the pump tonight :)
Andy c:
here is the list of pumps
95 589 236
NFP
HIGH PRESSURE HYD PUMP
DIAM 120
- PETROL
4007 T5
DIESEL FUEL AND 1,905L
PUMP 6 + 2
96 006 983
NFP
1 360L SINCE RPO 04193
95 638 565
NFP
GTI 16S UNTIL RPO 04223
96 034 023
NFP
GTI 16S SINCE RPO 04224
95 589 238
NFP
DIAM 90
- DIESEL FUEL
I wonder if that petrol lhm pump that i bought will fit the valver, hmmmm :)
i always thought the 16V shared the same pimp as the diesel's
edited
or even pump!!!!
Post by RxBX »
citronut wrote:i always thought the 16V shared the same pimp as the diesel's
:rofl:
Mike P
Post by Mike P »
The 16V pumps are specific, as per Rob's comment above.
The earlier and later pumps are the same operating specifcation but the later option is the better choice, as the large pipe connected to it is a better design and doesn't have the sharp bend in it that can fatigue and crack through.
I have had this happen to 2 of mine over the years and changed to the later pump and pipe to avoid a repeat performance.
Mike P
16valver
Post by 16valver »
i have a 16valve petrol that i'll be breaking do you need the pump?
Modstox257
If its in good order mate id be interested yes :)
Andy c:
16valver
Post by 16valver »
well when i get it running i'll see if it pumps up. i guess thats how i'll know if its okay. what will you need, pulleys belts? or just a pump?
Elliot
Modstox257
Il have the pulley pump and belt how much you thinking ? Price wise ?
Andy c:
