my diesel injection pump is not outputting fuel-something broken.Has anyone got one for a 17tzd?I rally need to get the car going again quickly'
thanks
urgently wanted diesel injection pump
Re: urgently wanted diesel injection pump
Hi, It may help if you state which type your looking for (Lucas/Bosch) to get a response to your requirements, good luck !
It is a Lucas which has packed in.I 'm wondenng if anyone has any knowledge on whether something from say zx or xantia 1.9 turbo diesel would do the job?
I've got a spare Bosch one with pipes, injectors etc....
Xantia TD (and 405 TD) is the same type of pump, and I'm sure it woud physically fit, but not sure about differences in delivery/setup.
- themildbunch
Are you sure the stop solenoid is working or it's getting 12v to it?
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
I wish it was just the stop solenoid but that was my first place to look-even removed the plunger.The pump has definitely packed in.
Pump is now on its way.Only the fitting to do once it arrives,thanks to Kevr
