When I came to having a look at the diff as a possible source I came across something which I do not fully understand ( not the first time of course).......................
The issue is the diff bearings in the pic. According to Haynes these taper bearings through which the driveshafts pass have an adjustment to set the preload by using a suitably sized shim between the removable speedo drive adapter (held in my gloved hand) and the left hand bearing, the right hand bearing just sits in the gearbox/diff housing and is therefore fixed.
Without some sort of adjustment the bearings would either be too tight or too loose and either grind or rattle or worse. Unless of course the components of the whole diff assembly are put together selectively to achieve perfect adjustment.
So following my diagnostic path I decided to check the preload by removing the speedo adapter housing to check the size of the shim present as I had removed the housing during the gearbox removal and it could have been lost. There was no shim in there. I then looked at two other gearbox diffs and found no shim present in these either. From this I deduce that the BOL is not correct and shimming is not done any longer.
So how exactly do you achieve that perfect preload of 0.01mm ? And if you fit new bearings things become more difficult.
[/url][/img]
