I'm hoping someone may be able to help identify which cars these various parts fit please:
Can anyone identify which cars the following parts fit please?
1 X 5449352 CV JOINT stamped with G7 E3>>55
1 X GS SIDE LIGHT LENS 5GX 955442265 (SEMA 434G) i'm guessing its for GS model?
1 X SWITCH AM 52202
1 X SUSPENSION CYLINDER REAR 3G 5475310 (BX20104 01A)
1 X HUB 3GX 75449347
2 X BRAKE PISTONS 4G 5435904
1 X BRAKE PISTONS 4GX 5435904
2 X HEATER CONTROLS 95550652
1 X VOLTAGE REGULATOR GX 1110901A
1 X HEIGHT CORECTOR 3GX 2119501A
1 X SPHERE 3L 5437354 (62-)
1 X SUSPENSION CYLINDER REAR 3G-W 5-475306 (G06 28B)
1 X HYDRAULIC REGULATOR PAINTED GREEN NO PART NUMBER, but found the following markings 95549648 (B1 279)
1 X TIMING PULLY GX 0135601A
1 X HEIGHT CORECTOR 3GX 2019501A
1 X FUEL PUMP 65CA 520414 POSS DYANE?
1 X GAUGE 09303009901 POSS FUEL model no = 0930.3009900 guage (recepteur essence)
Part Numbers
- MULLEY
Part Numbers
Re: Part Numbers
so were it you bought the job lot from ebay which sold for £100 i think
the first and only No. that came back with a match is
5 437 354
ACCUMULATOR SPHERE + GASKET
400CM3 PRESS 62 BARS
fitting
BX and XM
i would think other models also
im 99% sure all the No. with GX in will be for GS/A cars, and AM for AMI'S
maybe Malcolm Lockwood will help, if you havent got his No. i will post up on here later on today
5 437 354
fitting
BX and XM
- citsncycles
Re: Part Numbers
Might take me a couple of days to find it, but I have a GS parts book somewhere - I'll see what I can look up.
- MULLEY
Re: Part Numbers
- Stinkwheel
Re: Part Numbers
is a regulator for a non auto CX.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- MULLEY
Re: Part Numbers
Cheers Stinkwheel, i presume it fits mk2's inc the Gti Turbo 2?
- Stinkwheel
Re: Part Numbers
MULLEY wrote:Cheers Stinkwheel, i presume it fits mk2's inc the Gti Turbo 2?
From what i remember of CX'ing days then yes, i would expect it would, dont quote me though
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
