the 6+2 pump is for BX's without the FDV
i have this pipe for sale on flea bay
4020 XA
NFP
HYDRAULIC TUBE
FOR PUMP 6 + 2
i had a question asking if it fits a Diesel BX,
trouble is service citroen does not state what variety of BX/engine type it is for?????
any input would be useful
any UK BX's with the 6 + 2 pump
Stinkwheel
Re: any UK BX's with the 6 + 2 pump
Have you a picture of the pipe in question malcolm, that would help identification.
Edit, OK ive seen it on e-bay, sorry, should have checked first.
Its not a 14TU one, but it may be looking at it, a petrol 16 with no PAS one from memory, it looks similar.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
i would think it is for a power steering car, as it states on service citroen being for a 6+2 pump,
so this means as on the Xant's being power steering and without the FDV,
so it could be for a very late/one of the last petrol 1.6/1.9,
has anyone every seen a power steering BX without the FDV?????
on service citroens drawing it shows this pipe going from the pump straight to the regulator,
Does it look anything like the one on my white BX Malcolm?
i dont know Andy i havent had a look as yet,
but your white one has a FDV dont it????
Jayboy
Malcolm, it was me that asked the question on eBay. If it's 6.35mm pipe and uses the M12 nut at each end then it may still be an option. If it is, could you let me know the overall length and I might take a punt on being able to fit it.
CCC BX Columnist
'89 16v P1
'93 ZX Volcane TD 3 Door
'98 Xantia Activa P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
'89 16v P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
nop Andy your white estate has a FDVMothman wrote:Does it look anything like the one on my white BX Malcolm?
i thought it were you JayJayboy wrote:Malcolm, it was me that asked the question on eBay. If it's 6.35mm pipe and uses the M12 nut at each end then it may still be an option. If it is, could you let me know the overall length and I might take a punt on being able to fit it.
here is all it states on service citroen and no dimensions
4020 XA
NFP
HYDRAULIC TUBE
FOR PUMP 6 + 2
i will measure the length tomorrow
pm. sent
kind regards
malcolm
i have checked out this pipe today
it is 836mm from tip to tip, 12mm flare nuts, 6mm OD,
and one end has a conventional flare,
this must be because its for the 6 + 2 pump, i suppose Xant like
and the other has a citroen flare,
