rear wheel splash plates replacements
tim
A while back I wrote a thingy on Chat about Kurust, which turned out to be a crock of shit. Having done both the rear splash plates, or shields, worrever they be called, with a good coat of Kurust and Hammerite as well, I thought I'd saved 'em for the nation, but only three months later they were showing signs of rust all over, and this was late this summer before any bad weather. Two months ago one was showing holes. Yesterday there was a steady scraping noise from the back so I got underneath and removed the remaining half of the dangling plate which had simply rotted to pieces. Piggit.
So two questions - can anyone suggest a source for these? I thought I'd seen this somewhere quite recently but I've trawled the first four pages and can't find it.
And following on from my previous question on Chat, is there a rust protection material out there that is proven to work? Surely there must be a way of keeping rust at bay, otherwise we'll all finish up with lots of spare mechanical parts and hydraulic components, and no body shells to fit them on.....
Re: rear wheel splash plates replacements
I don't think there is a product out there which can convert anything but light surface rust long term into a stable substance, much as I'd like that to be the case! The trouble with rust converters is that they will treat what you can see, but how far do they penetrate into what's underneath? As a test, brush some on to rust, let it change colour and then take the grinder/sander to it. Chances are you will uncover untreated rust beneath.
I still maintain that removal is the only long term option, whether that be via mechanical means or by chemical removal. Of the latter, Bilt Hamber Deox gel is the only one I've tried, but it takes its time. Days rather than hours, but might be less of your time than it would take to manually remove the rust.
/\ as that. cure rust is great at doing what it is supposed to do, nowhere in the instructions does it say paint on the outside and it will cure all the rust underneath.
tim
Agreed - but if you have to remove all the rust back to bare shiny metal, then there ain't no rust to "Ku". It's a con.
I've found Vactan to be pretty good. Follow up with several coats of zinc-rich primer (my new wonder potion. It's brilliant) and a suitable top coat of some sort. Hammerite is complete crap.
My 2CV has rust EVERYWHERE. As an experiment, I rubbed down some rusty bits, coated in Vactan and then applied Bilt Hamber's aerosol zinc primer. Didn't bother with any top coat and where my coverage was good, no rust has returned after several months of Welsh weather. That's impressive.
If you abrade back to mainly bright shiny steel, the converter will probably neutralise any rust remaining in the pits. Or may well cope with light surface rust - which would be easily removed anyway! IMO it can be useful for slowing down rust in places like seams which are difficult to get to. Putting off the time when you have to do a long term job.tim wrote:Agreed - but if you have to remove all the rust back to bare shiny metal, then there ain't no rust to "Ku". It's a con.
That's paint-on rust removers covered - if I was cleaning up splash plates, once they were - visibly at least - rust free ( and I'd grind back to fresh metal before I even thought about putting Kurust on), I'd coat them in waxoyl afterwards. As the name suggests the splash plate is particularly vulnerable to . . . well . . . splashing.
Does anyone have access to a 3d printer so that plastic versions could be created, they won't rot
In principle Mulley, a good plan.MULLEY wrote:Does anyone have access to a 3d printer so that plastic versions could be created, they won't rot
However, (1) I guess it would be quite an achievement to get the engineering drawings on file from Citroen. (2) The finished plastic product may be as good as a chocolate fireguard when exposed to the radiant heat being emitted by the brake discs when they are doing their job.
Tinkley
- x 8
Yes, a 3D printed one would soften, maybe not completely melt. But a GRP one would be fine, it can take 100 deg heat no problem. Also you get significant heat loss with the air gap to the disc. Having tested elements at 400 deg which were encased (safely) by nylon mouldings I don't have a problem with plastics with a suitable air gap. The key is the stiffness which GRP would give compared to a single sheet,hence the light form in the pressing.
'Back plates'tim wrote:Having done both the rear splash plates, or shields, worrever they be called, ..
Sorry to sound pedantic, but don't you mean rust converters rather than removers? Which in theory can be painted on any thickness of rust, just that they will take considerably longer to work the thicker the layer.Paul296 wrote:That's paint-on rust removers covered - if I was cleaning up splash plates, once they were - visibly at least - rust free ( and I'd grind back to fresh metal before I even thought about putting Kurust on)
tim
As per my own experience, the stuff was a waste of time and money. I did as well as I could using a rotary wire brush and a drill, also a flapwheel. Sure, this doesn't remove all rust which is exactly what these wonder products are supposed to help with. But Kurust did nothing of the sort. There's a good blasting frim near me and with hindsight I could have had them blasted and primed, or even as suggested, slobbered 'em with Waxoyl. Anything would have been better! So there we are. For the bulk of the car where things can't be unbolted I am happy to try Vactan or a good primer - where can these brands be found??
And back to me other question - where can I buy a pair of new splash guards? Can they be cut out of a flat sheet of metal or are the various ridges and troughs needed to clear the nearby bits rather than just being structural?
PS I was told that if I'd fibreglassed the things carefully, thereby excluding oxygen, this would reduce the chances of rust a lot. Is that true??
here is price and part No. from citroen except they are NFP now
95630820 DISC PROTECTOR 12.69 GBP 15.23 GBP 15.23 GBP
Obviously, when I say 'remover' I mean remove in a converting kind of a way.mat_fenwick wrote:Sorry to sound pedantic, but don't you mean rust converters rather than removers? Which in theory can be painted on any thickness of rust, just that they will take considerably longer to work the thicker the layer.Paul296 wrote:That's paint-on rust removers covered - if I was cleaning up splash plates, once they were - visibly at least - rust free ( and I'd grind back to fresh metal before I even thought about putting Kurust on)
