TZD oil filter cooler hose - found a replacement!
KevR
As far as I'm aware, you can't get the hose which goes from halfway up the rad at the timing belt end, to the oil filter cooler. A while back I picked up something at a boot sale that looked like it ought to fit. Today I found that yes - it fits! It's another Pug/Cit genuine part, and it's a bit longer than the original and has to take a slightly different route past the injector pump plumbing, but works fine.
The only problem is I can't find out what it's supposed to fit to see if I can get any more! It was in original packaging, with the part no. 1307.R6 but I can't find a cross-reference for it. Anyone know? Or could check on the EPC (my PC which had the EPC on it has gone pop).
It'd be sod's law to find a replacement,and then find that NFP as well!
Re: TZD oil filter cooler hose - found a replacement!
Is this the one with (from memory) the 180° bend in it at the rad end?
KevR
Yep, that's the one. 180 degree square bend at that end, then a kink down to the cooler.
Hmmm, that's one of two original hoses on mine - I'd been wanting to replace it for reliability. I was thinking more along the lines of something like this and standard hose, although they do a selection of silicone hoses and joiners too.
I've seen those, but I must admit I've been thinking more of going down the route of standard bends etc. and joining pieces - more chance of a leaking joint but also more chance of making the pipe go where you want without it chafing.
here is price and part No. from citroen, although its NFP
96015636 WTR OUTLET HOSE 27.12 GBP 32.54 GBP 32.54 GBP
KevR
Does 1307.R6 come up as a cross-reference on the computer, Malcolm? I'm guessing it's from another XUD-engined car of some sort.
sure does KevKevR wrote:Does 1307.R6 come up as a cross-reference on the computer, Malcolm? I'm guessing it's from another XUD-engined car of some sort.
here is result from an all families search
2 document(s) found for RELAY
3 document(s) found for XM II
1 document(s) found for C25
00001317R6 WATER PIPE 12.29 GBP 14.75 GBP 14.75 GBP
KevR
Excellent, thanks Malcolm. Think I'll order one or two of those to keep in stock.
Now then, what about the big bottom hose from pump to rad on a TD....? Anyone got a source or a reference for a similar part that will fit....?
themildbunch
TD Bottom hose - Pretty sure this is unavailable now - I had AEP's last one I think a while ago...
Different from the N/A hose which has a t junction - I've kept my old one though with the thought of getting one or more made up at some point... welcome to lend this to anyone who wants to try this...
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
KevR
Not a bad idea - I know Jeff Winterman has had loads of hoses made for H vans. I'll have a word in the new year and see if his supplier would make some TD lower hoses, and if so, prices and minimum batches etc.
citronut wrote:sure does KevKevR wrote:Does 1307.R6 come up as a cross-reference on the computer, Malcolm? I'm guessing it's from another XUD-engined car of some sort.
Handy to know, thanks guys.
here is bottom hose for
this one dose not have a branch off to the oil cooler
95 612 501
NFP
RADIATOR OUTLET HOSE
DIAM INT 32 ET 36
DIESEL FUEL AND 1,769L UNTIL RPO 03795
and
DIESEL FUEL AND 1,905L UNTIL RPO 03795
the other option listed which does have a branch going to the oil cooler
still showing available
95 640 596
DIESEL FUEL AND 1,769L AND 1,905L SINCE RPO 03796
95640596 WTR OUTLET HOSE 58.28 GBP 69.94 GBP 69.94 GBP
and here is a third option but it seems no one has ever seen a BX with the 6+2 pimp
96 170 006
NFP
PUMP 6+2
95 612 501
NFP
DIAM INT 32 ET 36
and
95 640 596
96 170 006
NFP
PUMP 6+2
A BX with a 6 + 2 pimp eh
as in this threadDefender110 wrote:A BX with a 6 + 2 pimp eh![]()
http://www.bxclub.co.uk/forum/viewtopic.php?f=2&t=19034" onclick="window.open(this.href);return false;,
i have never seen a BX with no FDV from the factory either,
regards
malcolm
