Well, i did, wouldnt you?
Post by Mothman »
Came across this lot this morning on my way to Heathfield. Put her in high and she did the job, much to the amazement of the motors behind me!!
My Cars: LOTS!
x 122
Re: Well, i did, wouldnt you?
Yes , I've done it, in my 16TGS, a while ago.
Thread Bear
Post by Thread Bear »
Indeed it is another Citroen party piece. In use today. The Ock was flooded as usual and four wheel drives etc only could get to Wantage, save me. It was on the doors at one point but fortunately Gary seems waterproof. Less keen in a petrol but diesels are a safe bet with high air intakes. Not so sure about computerised modern nonesense though, if the starter goes under and leans on the battery. Also I believe cats get damaged by the quick cooling. Just so much easy having neither probs.
Not had to do it recently, but yes, done this in both BX and GS.
electrokid
Post by electrokid »
Oh yes - I certainly would :) After you've been through a flood with the suspension raised a couple of times I've found that the left hand automatically goes to the height adjuster when it's needed. I find that very pleasing - the fact that suspension height adjustment is something I do as a normal part of my driving experience :D
I was tempted once to move the lever to 'full height' and put up with the harshness of the ride knowing that I was well out of the water: not long after that the seals in the O/S rear leg blew and pissed green blood all over the car park at work - not to be recommended.
2002 C5 HDi SX estate
Tinkley
x 6
Post by Tinkley »
Yup, done that, and sometimes locked out on high. Nice little party piece. Electrokid could do it in Old Woking right now or yesterday.... Also around Brooklands... :lol:
electrokid
Yeah - I saw on the news that it was a bit damp around there: a friend of mine lives in Old Woking - I must send him an email to see how he's getting on with it.
I'm taking advantage of nothing much going on and just chilling out at home - might build a design idea - a low dropout regulator using a LM317T - maybe...
Thread Bear
Sorry, was that Old Soaking? :lol:
x 6
Well if it's good enough for Anton Rodgers, 15.04..." onclick="window.open(this.href);return false;
