Recently bought a gti, started it up today and i believe the front suspension has seized. Its incredibly stiff and doesnt bounce when i push down on it. What kind of work is needed to get this fixed and how much will it dent my already dented christmas bank acount? Its a right pain in the backside, its like im driving over offrad terrain when im on tarmac
It rose a little, although I think it didn't go the full way. Are they easy to replace? I have to admit to having no technical knowledge at all when it comes to mechanics.
Yes VERY easy, if you know how to do it, where are you based? raise the suspension to full height and see of it will go to its full travel.
If the front isnt at its normal ride height when driving and is sitting low it will give the feeling of being very stiff as theres no travel which could be a sticking height corrector.
I would try raising and lowering the suspension a few times and see if it levels out.
Hi Tom, if the suspension is soft now it's working again you don't need the spheres. What colour is the LHM? it should be a nice green colour, but it'll collect dirt in use and after a long time it'll und up brown and sludgy, with the sludge collecting in parts like the height corrector. If the fluid is dirty it needs ideally flushing, then changing with fresh LHM. if that doesn't do the trick, the height corrector will need removing and cleaning, although you need ramps or stands to do this, and it's not nice working outside this time of year!
My Cars: 1999 Xsara LX 2.0HDI (90) Hatch - Fern 2002 C5 2.0 HDI (110) Estate - Jasmine - SORN 2011 Mini Cooper D Clubman - SOLD 2016 Mercedes A180D Sport - Auto refinement 1992 TZD Turbo - Bluebell - SORN 1992 TZD Turbo Estate - SORN 1991 Gti 16V - Blaze - crash damaged, will get repaired - SORN 1990 Gti 8Valve SOLD - looks like it's been scrapped 2002 Mini Cooper S - SOLD - i miss this car 1992 TXD - Scrapped in March 2014 1988 CX 25 GTI Turbo2 - SORN 1996 - AX Memphis 1.5D - Dream - SORN
Probably a seized height corrector, was the suspension height lever very stiff when moving it?
Excellent! as mentioned above it probably a siezed height corrector, I would if I were you from time to time keep raising and lowering the suspension to keep everything moving freely.
My BX's can sometimes sit for up to 6 months in storage (they live a cossetted life) and when I run them I raise and lower the suspension a few times.
As Mike says, maybe a few fresh litres of LHM would be worth while!
Grr! Gary is now not settling to driving level after going through all the floods. He prefers tip toes. Its the height adjuster in all probability. Mine was sticky and needed cleaning up after lack of use. I expect it is sticking again or I failed to tighten the arm enough and its lost adjustment. So Citrobatics today. Oft times its the cure as the guys say. Cycling through the positions and getting the juices moving around the suspension. Front spheres sounds scary but it really is as easy as changing a spark plug, within the instructions of course. I did not believe it till I did it.
I changed the nearside drop link not long before you had it Tom. Maybe I should of changed both? The new one maybe a slightly different length to the other side. Thus the anti roll bar ight be sitting at a slightly different position. The LHM was changed quite recently so it shouldn't be that. One of the experts may shed more light.
MULLEY wrote:Probably a seized height corrector, was the suspension height lever very stiff when moving it?
not usually the height corrector its self, but more likely the linkage,
also as Tim inquired were are you located
Sorry, thats what i meant.
It seems to be the front nearside that's a little stiff Graham, sounds like i should do some research to find out what a drop link is and looks like . Thanks for your response Graham very much appreciated.
The LHM is still looking a nice green colour so i don't need to worry about that for the time being.
I'm guessing a Haines manual would be good to explain the drop links and height adjusters?
i dont think odd length drop links could cause one side to be stiffer that the other,
as both drop links are connected to each en of the anti roll bar,
they fit between the roll bar and a bracket on the back of the suspension strut
