ZX diesel pump compatability ?
Hi- please can someone tell me if a Lucas diesel pump from a 1994 ZX 1.9 non turbo is the same as (and will fit) my 1992- 1.9 standard BX diesel ?? thanks
- x 16
Re: ZX diesel pump compatability ?
If your old pump is Lucas, it's a bolt-on. If your old one is Bosch, you need also the injector pipes and have to change the mounting bolts of pump bracket to "the other" holes to get the timing match.
