Notchy Steering
Dominic
Notchy Steering
Post by Dominic »
Steering feels decidely odd on the TZD. Plenty of fluid (feels like a conventional power steering set-up with not enough fluid) and she's got new arms, driveshafts/CV joints, lower ball joints, so I don't thing its a bush thing. Getting tired of 'threepenny bitting' corners. Might be just my imagination, but feels worse in the morning from cold start. Any ideas?
Dom
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
Anything that turns money into noise...
Re: Notchy Steering
Sounds like a tired pump to me Dominic. When was the LHM and accumulator last changed.
Re: Notchy Steering
how quick dose she get up first thing in any day,
are the tank filters clean,
could also be air ingress via split/perished suction pick up from the tank to the pump,
or just air in the system from possible work that had been carried out at some stage
Re: Notchy Steering
Universal joint on steering column drying up and seizing?
Re: Notchy Steering
Cheap things to try 1st, pump belt needs to be very tight, check tank filters & clean accordingly. Is the lhm clean? if not do a full lhm change, its cheap but time consuming. Not sure how easy access is to the UJ that Kevan has mentioned? but again that might be a cheap fix with some grease needing to be applied. If all of those don't sort it, then as long as your tick time is ok, then the pump is tired :( or as Malcolm has suggested, perhaps there is air getting into the system? If you open up the top of the lhm tank, is there lots of frothing inside it (i'd use a torch to make it easier to see this) then air is the issue, or it may be a combination of some or all of the above.
x 138
Re: Notchy Steering
Post by rutter123 »
Typical lazy hyd pump symptoms, prob getting worse due to the cold weather.
michaelr
Re: Notchy Steering
Post by michaelr »
Make very sure that the pump drive belt is not slipping. As mentioned it needs to be tight and slipping will load up the steering intermittently.
I had a similar problem when I overfilled the radiator (silly design with the expansion tank built into the side of the radiator) and the overflow splashed on the vee belt.
Michael, Sydney, Australia
BX19TRI Automatic
DS23 Pallas
themildbunch
Re: Notchy Steering
Post by themildbunch »
The weak pump theory is most likely IMO.. I have had the same issue for a while. Power assistance intermittent for a short while in cold weather, when fine once the LHM has warmed up and likely got less viscous...
You might find using hydraflush or a mixture would help as it's thinner but not such a good idea to leave it in for too long -
There's a DIY pump rebuild thread somewhere but it needs a big puller!
Pleiades still sell recon pumps with a warranty but given it's not such a big job to swap I'd try some scrap ones first if you can get one or two cheaply....
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
badlyworntoy
Banned
Re: Notchy Steering
Post by badlyworntoy »
I had this problem on the 16v. Every morning I would haveto fight the steering for about 2 miles and then it would go knotchy and that was the best it got. I changed the steering ram and HP pump which made no difference and it turned out to be the Flow Divertor Valve.
Re: Notchy Steering
I'd forgotten about the FDV, that should be cheaper to replace than a pump.
Dominic
Re: Notchy Steering
Post by Dominic »
Thanks for the suggestions - its gonna be a green fingers weekend, I reckon. :mrgreen: I have a spare pump, LHM looks clean enough, but not sure about filters.
What is/Where is the Flow Divertor Valve?
Dom
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
RobC
My Cars: 1991 Citroen BX 16v
x 30
Re: Notchy Steering
Post by RobC »
The FDV is adjacent to the pressure regulator (which has the accumulator (the 'fifth') green sphere on it), on the front of the engine.
http://www.bxclub.co.uk/forum/viewtopic.php?t=2865" onclick="window.open(this.href);return false;
http://citroen.tramontana.co.hu/suspens ... istributor" onclick="window.open(this.href);return false;
1991 Citroen BX 16v
Re: Notchy Steering
I have the flow diverter valve to do on Timex I think. The pump is good, as is the accumulator, but the tick time is like that of a flat accumulator and it's slow to build up pressure. The power steering feels notchy for the first couple of miles in cold weather, or if the rest of the system is working hard (like braking on a rough surface on a bend), but sorts itself out when it warms up.
Re: Notchy Steering
Dominic wrote:Thanks for the suggestions - its gonna be a green fingers weekend, I reckon. :mrgreen: I have a spare pump, LHM looks clean enough, but not sure about filters.
For the cost I would change the LHM anyway
HZman
Re: Notchy Steering
Post by HZman »
Had that for over a year, sometimes wondered if it was going to get round a roundabout but just got used to it. Flushed the LHM system, changed the steering rack no difference. Recon pump fitted, different car!
