Folks My names Ian, Sorry just to barge staright in with a wanted add, but the 16v BX forum is very slow and hardly anyone seem to ever use it so I've moved over to here. I'm currently restoring a P2 16v which I've owned for 6 years. It was in the paint shop last year and they made a huge mess and lost most of the parts from the doors. I've since had it all sorted by a "professional" bodyshop and upon re-assembly I'm struggling to find some of the parts which I think the first knocking shop lost.
If anybody can help with the following I'd be much obliged.
1x black disc which goes on the front door cards to blank the hole were the manual adjuster would protrude on the non electric mirror models.
Right hand rear outer door handle
The correct screws wich hold the door catches to the door frame, they is 3 per door and I need 3
The coin tray which goes around the digital clock in the middle of the dash in black.
I also need the heater control valve which goes from the matrix to the bulkhead, I'd really like a new one of these as the secondhand ones I've found seem to be very brittle and when I attach the hoses from the engine I cant get them tight enough without spliting the pipes.
I'm also would like a good set or front strut tops, the flange with the 3 studs and the rubber donut.
Again many thanks
PARTS WANTED
Mike E (uk)
Re: PARTS WANTED
Hi Ian,
"parts which I think the first "knocking shop" lost.
I have found Car body shops to be considerably better for quality car repairs than brothels.
Back on topic:
I have a round blanking disk thing.
I have the screws, but will need to identify them in the 'Screws, various. Ex-BX' box.
I have a coin tray- the whole thing with the door.
pm me and we will sort something out.
Mike
Back on topic:
Mike
Re: PARTS WANTED
Welcome aboard, yes the 16v forum is very slow noadays as most of the founder members seem to have gone quiet or sold the cars on.....you are very welcome here and theres alot of 16v owners.
part locating shouldnt be an issue.
badlyworntoy
- Banned
Re: PARTS WANTED
Retro and Classic Worx in Derwent street Middlesbrough, ran by some character called Beano just makes a mess of cars as far as I can tell, hence the term "Knocking shop" might be a northern thing sorry for the confusion.
16valver
Re: PARTS WANTED
where abouts are you? i can get you said black disk for the mirror. a door handle. (black plastic.)
also, when you say you need 3 door catch screws. do you mean 3. or three sets of 3?
Elliot
Elliot
badlyworntoy
- Banned
Re: PARTS WANTED
Elliot
I'm in Middlesbrough and I only need 3 latch screws (1 doors worth)
many thanks
many thanks
16valver
Re: PARTS WANTED
Most of them do that, I just loosen the screw!
