Wanted: Driver's door, Red
- jamescarruthers
- x 23
I'd like a driver's door please.
It must be rust free.
I'd like it to be in Sunrise Red, which is a Mk. 1 only colour. it's for a BX14E so shouldn't have the black paint around the surround.
Alternatively, in Venetian Red so that I don't have to paint inside of it, just spray the outside.
And really alternatively, any old colour, I suppose, if I have to paint it anyway.
Last edited by jamescarruthers on Fri Jan 31, 2014 11:12 am, edited 1 time in total.
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
- jamescarruthers
- x 23
Re: Wanted: Driver's door, ideally Sunrise Red
To be even more picky, I'd prefer one with a manual window winder mechanism.
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
- Tim Leech
- x 141
You can swop the internals over from any doors James, the chance finding a sunrise red one is pretty much NIL as it was only available on Mk1 and most of those left seem to be blue or white.
If it were me I would get Mk2 and get it painted and then swop all the bits over, its fiddly but doable.
- jamescarruthers
- x 23
True, I'm just trying to keep costs down as I'm hella skint at the minute!
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
- Tim Leech
- x 141
No wories mate, how rusty is yours? could it noty just be repaired.
- jamescarruthers
- x 23
It's a gonner because of two faults. The previous owner blocked up the drain hole with Waxoyl, I think, so that's the back corner gone. It has also been hit at some point and poorly bashed out.
Other than that the car looks mint now!
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
- Tim Leech
- x 141
OK James, someone on here will have a door on here. I guess if you can get a venetian red bare door that would help. Ive swopped door sover, amother pair of hands is ideal, and to strip as much out of the door before you remove it, as your car has manual windows and locking thats easier!
- jamescarruthers
- x 23
Do I take it off by knocking out the pins? One of mine looks poorly so should be replaced anyway.
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
- Tim Leech
- x 141
Re: Wanted: Driver's door, Red
Yes mate. But lubricate the pins beforehand, and remove all the trim, windows etc if you can otherwise they are heavy and unwieldy when the pins are removed.
A assistant would be ideal!
- jamescarruthers
- x 23
Great, thanks mate.
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
- Tim Leech
- x 141
If you can get a pin removal tool it would be ideal, sometimes a punch and hammer and they just pop straight oit, but ive had some that you have to destroy to get out.
- mat_fenwick
- x 19
Seconded for a pin removal tool - it's difficult without it to avoid paintwork damage.
- citsncycles
If you get really stuck I have an early Mk2 base model door (manual window, no rubbing strip) in white, although I'll have to double check the shell's good.
Hi James, they may still be one available as in THIS F/S thread, however as its coming up to nearly TWO years since the initial posting (don't hold your breath) ?jamescarruthers wrote:I'd like a driver's door please.
Good luck !
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
I have a Venetian red door for free, currently on offer to another member but yours if it falls through
