Here is the problem:
When I got my BX it was leaking from the rear height corrector. When I got under and looked I found the dust cover and the diaphragm retaining ring were missing. Easy fix, I had spare rubber bits that also fit my DS!
A couple of weeks later it was leaking again... split diaphragm so replaced again.
And again! Dust cover gone, diaphragm split! The only thing I can suspect it that the plastic vent pipe is blocked and leak-by fluid is blowing things apart.
I can find no place where the plastic pipe is pinched under the sills, where else should I look? Maybe if I know where the vent pipe can be found at the reservoir I could blow a little air back down the pipe? In the mean time I think I will lead the vent pipe into a "catch can" after checking the internal passageways in the corrector for blockage. Any other suggestions?
Rear height corrector vent tube
michaelr
Michael, Sydney, Australia
BX19TRI Automatic
DS23 Pallas
BX19TRI Automatic
DS23 Pallas
